Menu problem with the Joomla
I have been working with Joomla in long time but recently when I created a menu in using joomla menu manager and assigned the links also then it is not working and does not preview the menu.
I need the suggestion from the Joomal expert.
Answered By 5 points N/A #124720
For your menu problem on your joomla, this problem related with joomla's User Interface. But to fix this problem is not too difficult, because all you need to do is refresh the page, then see your menus show.
But if your menu still doesn't show, go back to admin page, make new menu on Menu Manager. Put unique ID: topmenu, then move all your menu links below this topmenu. After that, go to Extensions next Module manager. Set the Top Menu module position to user3.
Refresh your page, and see the result. Hope this tips can help solve your menu problem 🙂
