Merge and Resize the Layers in Adobe Photoshop
Hi Lamily2,
Merging Layers in Photoshop are great tools which you can use while working with Adobe Photoshop. But if it has to many layers it will only cause disarrangement. If you increase the file it will slow down your Adobe Photoshop.
Here's How:
Hope this might help you.
Thanks,
Aliyah
As a beginner try to make fun with Photoshop do as you want. What your mind want to paint, just paint it. Then if you have more than 1 layer you can merge them by following steps: at first open the document and go to this option when the whole document is selected. Layer > merge layer. Or you can merge what you see by go to layer > merge visible. Now if you want to resize any layer just select the layer and press “ctrl + t” you see that borders come get your mouse little on any angle you will see that your cursor change to resize sign now drag to resize it and press “enter”.
