Merge multiple Corel files into one
Hi All,
I need to know how to merge multiple Corel files into one,
Please suggest me the process of doing the same.
Waiting to hear from you.
Thanks, Mary Drapper
Hi All,
Here one  thing you can do is to publish it to PDF.For doing this you have to select all files and open in Corel.
Then publish it to PDF. Select settings and then select the documents.Here all of your documents should be checked.
Make what ever the changes you need and save it. This will put all in a single PDF page.
Another method you can adopt here is open one of those files and import the next one and place it on a new PDF page.
Repeat this step until you have placed all your Corel files into the single PDF page.
