Merge or join aac audio files for Mac
Dear Friends,
I would like to know about, How to merge or join aac audio files for Mac, Is there any specific software available for that, Please advise.
Thanks and Regards,
Aracelirystal
Dear Friends,
Thanks and Regards,
Aracelirystal
AAC is an audio file format. As you are using Mac, it is hard to find out specific program for this purpose. But don’t worry, there are softwares for this purpose.
Here is a software called “Toolsoft Audio Tools”. It is a nice tool. Though it is shareware program, it should do the work you desired.
Also, there is a program called “Audacity”. It is a powerful audio editing tool that supports AAC file format. You can make a nice play with AAC files you have got.
Hope you will enjoy using these tools.
Hi Aracelirystal
Yes there is. Let me introduce you to Video Joiner. It merge audio and video files, you can convert or edit them.
Merge audio files like mp3, aac, flac, m4a, m4b, ape, wav, wma and many more.
Run Video Joiner and a pop up will appear drag files and add them select a file where you want to merge it.
