Merge Several PDF files into One File
Hello Erni.
You need a tool that will let you merge PDF files. Â
You can use Bullzip PDF printer to merge PDF documents while printing but I must admit it is very complicated to do.
I recently discovered this free tool that lets you merge PDF files.
It's called PDFill and you can learn more about it from here:Â
1. Â Download and install PDFill. Â
2. Â Once installed, go to Start Orb -> PDFill -> PDFill PDF Tools (FREE).
3. Â Press the "1. Merge PDF files" button.
4. Â Drag and drop the PDF files that you want to merge.
5. Â You can arrange the files in the order that you want to merge it. Â Use the "Move Up" and "Move Down" buttons.
6.  Press "Save As…" and supply the name that you want.
7. Â Your PDF files have now been merged!
Since you are looking for a program that will allow you to merge or combine several PDF files into one single PDF document, trying A-PDF Merger would be your great choice.
It is a lightning fast and simple desktop utility application that allows combining two or more PDF files into one single PDF document. And also, besides combining several PDF files, you can also merge several image files into one PDF file. You may also merge Microsoft Office files using A – PDF Merger by installing another application called A – PDF Office to PDF.
Here are some of its features:
To download the latest version, A – PDF Merger 4.7.0, you may visit A PDF Affordable PDF Tools A-PDF Merger.
It supports Windows 2000, Windows XP, Windows Vista, and Windows 7 and costs $35.
Screenshot of A – PDF Merger
