I made two MS-Word documents which I will be used for reporting. The first file has 15 pages and the other one has 5 pages. How can I merge the two and make it a single file with a total of 20 pages? Can anyone help? Thank you.
hammad90
Merge two Word documents to make it a single file
You can Merge your two MS Word files eaisily now, first you open your 5 pages file and copy all data from the file and then open your 15 pages file and go to the bottom of the MS Word file and then press Ctrl+Enter for going to next page and then write the headings of the 5 pages documents and then paste your 5 pages data and save it. Thanx
You can not merge as well as combine two documents bacause it is not allowed in microsoft word document. You can only add one file to another file(copy paste work).Thank you.
