Message receive with POV Ray.
Hello Andre Mckenzie,
I think the error is being caused by how you are implementing the process. I will suggest that you try separating the chapters in povray by time, so that you may have like 2 or 3 scenes that can happen in the same frame but from two different povrays. Or you may alternatively choose to swap the povrays from one to another but in the same.
You can swap the pov as many times as you want, you can play any scene for each MC that you have by choosing which one is compelling to whichever section but sometimes the results may be tragic causing the errors as the ones you have posted above. So just be cautious of the actions that you take when using povray.
__
Regards
Clair Charles
If this is the first time that you have encountered this error, try restarting your computer and then run the application again. If it sill generates that error, run a disk check on your computer to see if your system has a problem that is causing the application to generate this error and to not work properly. If you have a disk utility application installed on your computer, run it to check your hard drive for errors. Or if you don’t, just use Windows disk check instead.
After the disk check run the application again and see if it works now. If it still displays that error, check your work if you are putting or entering an acceptable value or option.
