Mia Molly
20 points
Posted on - 10/12/2012
Hello Experts,
A method on converting wmv audio to mp3. I need some software free download from the internet that will allow me to convert my wmv audio files in to mp3 files. Can you suggest the best converter that you ever tried in your past experiences? I know you can help me.
Thank you.
Dana Cua
5 points
Hi, Mia.
I have tried so many audio converters and YouTube download is the only one which worked for me. There are other choices but YouTube download is easy to use. Now, I am using this converter and it works fine, too. It will help you convert a video file to Mp3.
Have a good day.
Hello Mia Molly,
It is an audio converter software that will help you convert wmv to mp3 file and other audio, such as wav, mp3, wma, m4a, ogg, mid, flac, mov, amr, aac, au, aif, raw, dvf, vox, gsm, dss and other audio format. This software is such a user-friendly, anyone with a basic knowledge in converting audio files can adapt using this software, so I recommend this to you.
I hope this help you.
Here is very easy to use and Freeware Software “FORMAT FACTORY”, go to link given below and Download the .exe file, make an installation of it. Run the program. In the side bar you’ll find an option Audio, go to it and click and you’ll find a dropdown list, there you have to choose MWV to MP3, select it.
Now in Program window you have an option of Add File, do select that n choose your source file. Now this program has a feature that you can easily find output folder of converted file, from the tab Output Folder.
Here is the link: http://www.pcfreetime.com/
