Method to drop the master table in SQL
Which method should be used to drop the master table if its primary key is being referenced by a foreign key in some other table ?
Hi Jgulliver,
Before can you drop the master table you have to drop the foreign key on the other table first. To drop foreign key, use the following SQL:
MySQL:
ALTER TABLE <table_name>
DROP FOREIGN KEY <f_key_name>
SQL Server / Oracle / MS Access:
DROP CONSTRAINT fk_PerOrders
In addition, you need to make sure that there are no other foreign key relationships referencing your table.
SELECT *FROM sys.foreign_keys
WHERE referenced_object_id = object_id('<primary_table_name>')
And if there are any, drop those foreign key relations:
SELECT
'ALTER TABLE ' + OBJECT_NAME(parent_object_id) +
' DROP CONSTRAINT ' + name
Now you are free to drop the primary table
DROP TABLE <table_name>
I hope it helped.
Notifications
