Method On How To Open RAR Files On PC Given
I want to know methods on how to open RAR files on PC urgently as I need to open some important files. If anyone of you knows how to do it then please tell me. Thank you.
To open RAR files –
http://download.winzip.com/gl/nkln/winzip21-lan.exe
This is how you open RAR files on PC.
A RAR file is a compressed file that uses the .rar extension (*.rar) created or compressed with WinRAR. WinRAR is a file archiver just like WinZip and 7-Zip but unlike 7-Zip, WinRAR and WinZip are both commercial software which means users need to purchase them to be able to use them for good with all features activated.
You can also use them for free without paying a cent using their trial version. But trial applications have limitations in terms of features and the entire length of their usage. You can only use them for a limited time like sometimes 15 days or 30 days depending on the application. Since you want to open or unpack a RAR file, download 7-Zip File Archiver.
It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. Unlike WinRAR and WinZip which are commercial software, 7-Zip is a free, open source application which offers better compression ratio than the two. 7-Zip can pack or compress files in 7z, XZ, BZIP2, GZIP, TAR, ZIP, and WIM formats.
It can unpack or extract files in the following formats: AR, ARJ, CAB, CHM, CPIO, CramFS, DMG, EXT, FAT, GPT, HFS, IHEX, ISO, LZH, LZMA, MBR, MSI, NSIS, NTFS, QCOW2, RAR, RPM, SquashFS, UDF, UEFI, VDI, VHD, VMDK, WIM, XAR, and Z.
