Can you suggest a method in order to find MS Outlook.PST file. The file is present in a client system, and I also want to find out which profile of Outlook it is associated with. We are currently using Outlook 2003 version on Windows XP system.
Please suggest some ideas.
It would be a great help to me. Thank you.
Method in order to find MS Outlook.PST file.
Hi, I am here to assist you searching the PST file. Please refer the following guide given below :
1.   Firstly, launch your Microsoft Outlook. On the top of the level item in the tree view, please right-click on a folder whichÂ
    typically been called as Personal Folders or Outlook Today and then select Properties.
2.   Next , once the Properties window has prompted out, please move your mouse to the Advance button and click on it.
3.   Now you get the full path of the PST file location. As shown in the figure below, the path location is inÂ
       C:xfermailpersonal.pst
Yours might be slightly different. Since you are currently running on Windows XP, thus the default location is normally under
Documents And Settings[username].
Note : the username is your login credential name in Windows.
