Method of psp import video from pc
I want to import videos from pc to psp but do not know the procedure of doing it. Please tell me the method regarding psp import video from pc.
First thing to do you have to convert it to mp4 or mpeg4 format. Plug the psp into your computer with a usb connector after that you open my computer and find in the local disk and to all disk drives until you get to the psp then click on the videos folder. You have to drag your video there, do not change the name of the video that you drag or else it will not work.
Of course in addition you have to again update your computer operating system recommended updates if there are. And always keep your windows firewall on and antivirus for security reasons.
These are the easy steps of moving a video file from your pc to your psp.
1. Connect USB cable from your PSP to PC.
2. Open "My Computer" on your desktop.
3. Then double click on the name of your PSP's memory card.
4. You will see a lot of folder in your PSP's memory card. Choose "VIDEO" folder.
5. Copy your movies to "VIDEO" folder.
6. Make sure that the format of your movies are in MP4.
That's it! Enjoy!
Stafford Meza
Because of the large viewing screen that the Sony PlayStation Portable has, many users love watching videos directly on the PSP device. If you already have the videos you want to put on your Sony PlayStation Portable device, the very first thing you should do is to convert those videos into PSP compatible formats. To do this, you need to have a video converter for PSP.
Try using ImTOO MPEG Encoder. This application allows you to convert a video into Sony PlayStation Portable format and many other video formats. Once installed, run ImTOO MPEG Encoder then load the video to convert. Under Target Profile, click on the dropdown list, point to PSP, and then select the format you wish to convert to. See image.
Click on the red circle button to begin converting. Once the video is converted, the next thing you need is a card reader. Insert the Sony PlayStation Portable Memory Stick to the card reader then connect the card reader to the computer. Browse the Sony PSP Memory Stick with Windows Explorer. Create a new folder named “VIDEO” on the Memory Stick media or in the system storage.
After that, copy the video you converted into that folder. You can create folders inside the VIDEO folder up to the second level. For Sony PS3 devices, the VIDEO folder is created automatically so there’s no need to create another one.
Notifications
