Method To Check If Windows Is Genuine Or Not
I want to check if Windows is genuine or not and I don’t know to hope to do that. People please help with this problem. Any assistance will be deeply appreciated.
To check whether your OS is genuine or not-
http://www.microsoft.com/genuine/validate/
If you have Microsoft Windows 7 but you are not sure if it is genuine or not, there are different ways to validate the authenticity of your operating system. The first method is from within Windows 7 itself. Click “Start” then in the search box type without quotes “activate windows” and then click “Activate Windows” from the results.
If Windows 7 is genuine and activated, you should receive a dialog saying “Activation was successful” with the Microsoft Genuine logo on the side. Another way of validating Microsoft Windows is by visiting Genuine Microsoft Software using Microsoft Internet Explorer otherwise it will download a small program when you click “Validate.” The third option is from the Control Panel.
Click “Start,” “Control Panel,” “System and Security,” and then “System.” Scroll down until you reach the “Windows activation” section. It should display “Windows is activated” plus the Product ID as well as the Microsoft Genuine software logo.
