Emaily Rawa
10 points
Posted on - 12/21/2012
Hello techyv,
How to use the process killer for Nokia n95? A process killer is when you had opened too many applications and have nothing to do about it but to terminate some application which is not responding to the server anymore. This is a big help to avoid the mobile device to freeze and hangs. What would be the process and the function key for process killer for Nokia n95?
Expecting some help from you guys. Thank you.
Method on using the Process Killer app on Nokia N95
Hi there Emaily:
‘Process Killer’ or ‘Application Killer’ is quite equivalent to nowadays ‘End All Running Applications.’ If you have it already, just install it into your Nokia Phone and it’ll automatically kill running applications which are no longer responding to the server.
I suppose you have this application already, only not aware how to use. But anyway here’s the link to download it for free. http://softwaretopic.informer.com/nokia-app-process-killer/
Best regards,
