Methods to create user in active directory
I am new to Windows Server and don’t know how to use it. First of all, I want to create some user accounts, and for that, I ought to learn some methods to create user in active directory!
There are two ways for creating new user in active directory:
Method 1:
• First, login to windows server using domain-connected PC (Make sure that you have RSAT already installed)
• Now, click on Server Manager near Start button.
• Select Active Directory Administrative Center under Tools menu.
• On the left pane, go to the ad(local), and then click on Users
• Go to tasks pane, click on Users, select New, and then choose User from the list.
• In the dialog box that appears, fill all the required fields (you can leave the fields empty that don’t have asterisk mark)
• Click on OK, and your account will be created.
Method 2:
• Start Server Manager, go to Tools menu, and open Active Directory Users and Computer.
• Now, from the left pane, elaborate domain, and choose Users.
• From the right pane, right-click anywhere, and click on New, and then User.
• In the pop-up dialog box, fill the fields, and click on Next.
• Enter the password, and click Next.
• Confirm the information, and click Finish.
• Your user account will be created, and you can access it from the Users container.
Notifications
