Methods that I can use to transfer data with windows easy transfer
To migrate data with windows easy transfer you can use following three methods.
Easy Transfer Cable:
This is a special cable with USB connectors that you can purchase from hardware vendors. You connect one end to the source computer and the other to the destination computer.
Network:
To use the network migration method, you must have two computers running Windows Easy Transfer connected to the same local area network.
External Hard Disk or USB Flash Drive:
You can specify an attached external hard disk or USB flash drive. It is also thinkable to specify an internal hard disk drive or network share when using this method.
Thank You
John Major.
