Methods To Change Centimeters To Inches
There are so many units are centimetres can change the one unit into another, so I don’t know how to change centimeters into inches using the various methods?
Methods for change centimeters into inches:-
Method 1:- Using MS Word
1. First, open the Microsoft Word click on the file option.
2. In the file, option-click on the Options after that the popup window display.
3. On the popup window, click on the Advanced option.
4. Then, scroll down until you see the display section.
5. Click on the Show Measurements in Units of the dropdown list and select the Inches option.
6. At last, click on ok.
2:- Using Excel
1. First, click on the File then click on Options.
2. Then click Advanced option.
3. Now on the Ruler Units drop-down list, select Inches.
4. Then click on, ok.
