Methods To Convert Rpt To PDF Files
What are the various ways to convert rpt to PDF? What are the different types of soft-wares which are used for this kind of conversion?
PDF24 provide numerous online applications which are used to generate PDFs. The converter examination has diverse interfaces. The PDF24, Online PDF Converter wires a lot of records which can be converted to PDF. Only select RPT file which you would like to have a PDF description, click the “convert” key and get a PDF version.
Or
The free and trouble-free to make use of PDF24. Click on the download to download the “PDF24 Creator”. Install the software. After that, you will be having a new printer registered in your Windows system which you can make use of to generate a PDF folder from your .rpt folder.
An RPT file (.rpt) is a kind of report file created by Crystal Reports and intended to be used with Microsoft Visual Basic. It can be opened using Microsoft Visual Studio or SAP Crystal Reports and may contain information from many different database sources. If you have an RPT file and you need to convert it into PDF, here’s one way.
First, you need to convert it into XPS format using the Microsoft XPS Document Writer included in Microsoft Windows. Open your RPT file with the program you normally use like Microsoft Visual Studio. Once the file is opened, click “File” then “Print” or just press CTRL + P. On the next screen, select “Microsoft XPS Document Writer” as your printer then click “OK” or “Print.”
Select the folder where to save the XPS file then click “Save.” When it is finished, open your web browser and go to Online PDF Converter. Upload the file, and click “Convert.” And that’s it. Just download the resulting PDF file on your computer.
