Mezzanino Sales Area 1: Error Creating Rooms File
I faced a problem during the time of manipulating room loads for a LEED guarantee. The model has built with 6.4 versions, after that I have upgraded to IES2012 and at this time, although observe that "replace" button was gray in Baseline case, I have installed hotfix2. Currently I can amend Baseline structures however, at the end of load manipulation I have found this error message. I have built again the model in model settings and calculate again shading file however not anything has amend. Error message information a method to set Cliopenings reasons however I could not recognize what is "key-in box". Some suggestions would be appreciable?
ModelIT: Go to the key-in-box
Unable to find the connected opening for room ‘Mezzanino – sales arena 1’, surface [4], opening [0], the opening may encroach into the wall volume due to a change in construction thicknesses.
Try the following in ModelIT: Go to the key-in-box, type ClipOpenings <return>. Then save the model.
Best Answer by Baldwin Coll
Answered By 0 points N/A #175834
Windows XP Professional, with a less advanced powered Windows Server 2008, by utilizing IIS 7.0. Unluckily, the switch to IIS 7.0 was not a simple one at least. Apache was a little solid to select up initially, although minimum roughly every one of the configurations were accumulated in a middle text file that could be simply edited, and was extremely configurable. And also, you installed Apache, (and PHP 5) inserted conservatory in the HTTPS file, pointed again the house list, and some additional slight configurations
Answered By 65 points N/A #175835
There are possible solutions that can be done to solve your problem. Upgrade your database. This is done especially if you will be using new software. Make sure you have the permission to connect to database. Check that mezzanine is running. Check DNS definition. Make sure there are enough memory segments. Check available swap space. Install the latest version of java if needed. Try using a different browser such as Mozilla and Google Chrome. Make sure your internet is not slow.
