MFC J430W Multifunction printer ?
Hey any one tell me where can I buy this MFC J430W Multifunction printer which has now half price sale on it.
Can I buy this one online for the same half price?
Dear User,
There is no special note about giving this away for the half price.
But if you want to buy it online you can refer to the links provided below.
Check the prices if it matches your prediction
Thank you
Actually you can try amazon for this type printer.
Except this, for second hand- you can try the buy and sell market.
But I think, it is best to buy the new model to avoid the further disadvantages of printers.
Most of the printers are unusable after the age of nine months.
Thanks
The Brother MFC-J430w All-in-One Multi-function printer is a discontinued model. It features a built-in wireless network capability which allows you to easily set up wireless network using Wi-Fi 802.11 b/g/n. It also allows you to perform an unattended copy, scan, or fax up to 20 sheets using the auto document feeder. It has a 1.9-inch color LCD screen which allows you to easily read the help menus.
It supports Windows XP Home 32-bit only, Windows XP Professional both 32-bit and 64-bit, Windows Vista, and Windows 7. For servers, it supports Windows Server 2003, Windows Server 2003 R2, Windows Server 2008, and Windows Server 2008 R2 both 32-bit and 64-bit. For Mac, it supports OS X 10.4.11 Tiger, 10.5.x Leopard, and 10.6.x Snow Leopard.
If you are looking for stores that still offer this printer, you can try the following:
Unfortunately, this is the only one I found that still sells this model. Some of the stores are no longer selling it and was replaced by the succeeding model.
