Hi. I just purchased a 1-port Intellinet MFP 802.11G print server wireless USB so I can print wirelessly from any computer on my network. The problem is, my PC could not detect the MFP network adapter wireless. Do I still have to configure this? I'm on a Windows XP system. Thanks.
Mfp network adapter wireless not detected
Yes, you still need to configure it before your computer can detect it. Intellinet MFP comes with a driver CD which you can run with Windows 2000, XP, Vista and 7. Run the driver and install the Setup Utility to your computer. If you don’t have it, you can download it from the link below:
Download 1-Port MFP Print Server USB Driver
You can also get the manuals from the link above. After successfully installing the driver, connect the 1-Port MFP Print Server to your computer. It will then be detected since the driver is already installed. And you can now be able to share printing, scan, card reader and fax.
