Micro Soft Excel – Microsoft Office
MS Excel workbook can be share with other user and allow two users to use workbook at same time. Which feature is being used in this function?
It is possible to create a shared workbook and store it on a network location where various people can modify the contents at the same time. An example is when people under the same workgroup that handles projects and one needs to check on the status of each projects, the workgroup can use a shared workbook to trace the status of the projects and amend the information if needed.
If you are the owner of the shared workbook, you can handle it by controlling the user access on the shared workbook and fix any issues. When the changes is done, you can stop the workbook sharing.
Instructions
Tips & Warnings
In the event that two users edit the same cells in the Excel file, the second user who saves the workbook is presented with a pop-up question. This notifies the user that she has made changes to a cell altered by another user since her last save. She is given the option of keeping her own changes, and thus deleting the other user's, or deleting her recent changes. This is the common default practice when sharing Excel spreadsheets. However, this behavior may be turned off in the "Advanced" tab of the "Share Workbook" window.
