Is Micromax TouchScreen Mobile a good communication gadget for a person who doesn't require too much phone applications but a lot of phone calls and sending messages?
I work in sales industry so I require more than one mobile phone number.
Is any Micromax TouchScreen Mobile model worth buying?
I think you can buy Micromax Superfone Ninja 4 A87 at Rs. 5,449 only. It's best for you because almost every requirement you have fulfills this product.
Looking at your requirement details I would suggest you to buy Samsung touch screen phone instead of Micromax. As you do not require much more applications but you will be using the phone for more and more calls, SMS so Samsung will be a better option in this case. Micromax is not a good option here. Samsung is more reliable as per your requirement. So please rethink about it. Rest is in your hand.
If you want a Micromax phone that is dual SIM, you can check out Micromax Infinity N12. The Micromax Infinity N12 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was announced to the public and released on December 2018 measuring 156 x 76.2 x 8.5 millimeters and weighing 164 grams.
It is dual SIM and uses nano-SIM card. It has IPS LCD capacitive touchscreen display with 16M colors at 720 x 1500 pixels screen resolution. It ships with Android 8.1 Oreo powered by 12 nm Mediatek MT6762V Helio P22 chipset, 2 GHz Octa-Core Cortex-A53 processor, and PowerVR GE8320 GPU. It supports microSD expandable up to 128 GB. It runs on 3 GB RAM with 32 GB internal storage.
The primary camera is dual camera: first camera supports 13 megapixels with PDAF and second camera supports 5 megapixels with depth sensor featuring LED flash. It supports 1080p video recording at 24 fps. The secondary camera supports 16 megapixels featuring LED flash and supports 1080p video recording.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic, Wi-Fi 802.11 a/b/g/n with hotspot support, Bluetooth 4.2 with A2DP support, GPS with A-GPS support, FM radio with recording support, and microUSB 2.0 with USB On-The-Go support. It has built-in rear-mounted fingerprint, accelerometer, gyro, and proximity sensors. It runs on non-removable Li-Po 4000 mAh battery and available in black, Blue Lagoon, Red Velvet, and Viola colors.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
