disoja jully 10 points N/APosted on - 02/15/2013
I would just like to ask if my Micromax Windows mobile phone's OS is upgradeable just like in Android phones? I have the Micromax W900 with 128 MB RAM, K3 Hi3611 460MHz processor and Microsoft Windows Mobile 6.1 Professional OS.
Definitely! You can upgrade your Micromax W900 with 128 MB RAM, K3 Hi3611 460MHz processor and Microsoft Windows Mobile 6.1 Professional OS. But I am sorry to say that your cell phone's feedback is not very good.
I think it's better to change it and look for a new one. But it is up to you.
Some service centers do offer upgrade with Micromax W900. I would suggest that you visit the nearest service center and ask them if they offer the service. Upgrade is from 6.1 to 6.5 version only.
Check the comparison chart between two versions below.
If you want to upgrade the mobile operating system of your Micromax phone, that would depend on your phone’s hardware specifications. If your phone is quite newer, you might be able to upgrade or update to the latest but if your device is a little bit older, you may be able to update but up to a certain version only.
Micromax W900
The Micromax W900 is a discontinued 2G Smartphone operating on 2G network band using GSM network technology. It was announced to the public and released on February 2010 measuring 112 x 55 x 14.2 millimeters and weighing 113 grams. It uses mini-SIM card. It has TFT resistive touchscreen display with 256K colors at 240 x 400 pixels screen resolution.
It ships with Microsoft Windows Mobile 6.1 Professional powered by 460 MHz K3 Hi3611 processor. It supports microSDHC. It runs on 128 MB RAM with 256 MB ROM. The primary camera supports 2 megapixels. There is no secondary camera. It has 3.5-millimeter jack, Wi-Fi 802.11 b/g, Bluetooth, GPS with A-GPS support, and proprietary USB connector.
There is no stereo FM radio. It has built-in accelerometer sensor. The pre-installed web browser supports WAP 2.0/xHTML. It runs on removable Li-Ion 1500 mAh battery with standby time up to 480 hours and talk time up to 5 hours. It is available in black color. To see if your phone has an available update, on your phone, go to “Settings,” “phone update” then tap “check for updates.”
If an update is available, it will begin downloading automatically. Note: before checking for an update, make sure you are connected via Wi-Fi connection and you have at least 50% battery.
1....
