Microphone boost Windows 7 download
I am getting static noise when i boost my USB Mic, Is there any Microphone boost Windows 7 download that will not be having such issues.
Your microphone’s volume settings plays an important role on the quality of sound it produces. Downloading Microphone software booster may not be the answer to avoid static noise when you increase your microphone’s volume. We may also consider grounding issue with your computer especially if the microphone is directly connected to it. In such cases, it is probably your system or its power supply that has grounding issue. Try to check if the outlet your computer is plugged into is grounded well.
