Microphone settings configuration-settings are reconfigured
I am having some problem related to microphone settings. It was working perfectly. I think there has been some changes in the settings but I cannot fix it. So I need someone to give me instruction about how to fix this problem. It is very important for me since I have to talk to many peoples via skype. So please give  the solution ASAP.
Benjamin Morgan
Answered By 15 points N/A #117492
Make sure that the audio input used in your Skype is the correct device.
1. Open Skype.
2. Click Tools then select Options.
3. Click Audio Settings tab.
4. On the drop down menu of Microphone, select your default Audio Input or Microphone.
5. Make sure that the device is connected properly on your Computer for Skype to detect it.
If the device is working properly, the Volume bar should be moving or should display that sound is detected. If only little activity is shown, uncheck the “Automatically adjust microphone settings” then change the volume of the Microphone.
To troubleshoot further, click the Make a free test call found at the bottom part of the window.
