Microscope Special Effects software error
I have realized that every time I launch the Microscope Special Effects Software the following error message appears .Why is this happening? I have tried the solution provided on the error message but it has not worked yet.
An error has occurred.
Make sure your microscope is connected, then try restarting the application. If you are still having problems, disconnect your microscope, reboot your computer, then reconnect your microscope (103)
