MicroSD Memory Card Not Being Detected by Acer Aspire X3200
I am using an Acer Aspire X3200 which has a built-in multi-format memory card reader located in the front panel of the CPU. I used to be able to just insert my microSD memory card enclosed in its adapter into the slot for the memory card reader and it would be detected right away but now when I do this, it is no longer being detected by the computer.
I already tried using another microSD memory card, even another adapter but it gives me the same thing. Could this be a possible virus issue? I even suspected that dust could have accumulated in the slot for the memory card reader so I cleaned it using a vacuum cleaner made just for computers but still no change at all.
I would appreciate any help that you can extend.
