Microsoft Access Database Engine 2010 installation error
Hello.
When I was installing Microsoft Office (Microsoft Access Database Engine 2013 Redistributable), I have encountered this error message:
Hello.
Hi George,
It appears you already have 64-bit version of MS Office installed in your system.
The error reported by you comes up only if you have 64-bit version installed that is incompatible with 32-bit version you are trying to install.
Moreover, you cannot install 64-bit and 32-bit versions of Office 2010 applications on the same computer.
The solution would be to have products from the same version. If possible choose the 32-bit version, an approach recommended by Microsoft as well as that would allow using third party add-ins which are available for 32-bit versions only.
Hope this helps you fix the issue.
Mclean Buono
