Microsoft Application Virtualization (App – V)
Hi
I have an App-V 4.5 CU1 2003 streaming server.
But it is no longer allowing latest applications.
Also in the last page of the applications wizard, I got the following errors:
Application Virtualization Management Console
As well as the sftmmc.log details of an Internal SQL server error message, also sql server is running as well as I am able to check the database link without any troubles.
Clients are also streaming applications with no issues, but still I need to insert new apps.
Here is the sftmmc.log:
11.06.2012 12:49:56 http://ngappv1/
ManagementConsole.MCException: Internal SQL Server error. —> SoftGrid.Management.AddApplicationFailedException: Internal SQL Server error. —> System.Data.OleDb.OleDbException: Internal SQL Server error.
at System.Data.OleDb.OleDbCommand.ExecuteReaderInternal(CommandBehavior behavior, String method)
at System.Data.OleDb.OleDbCommand.ExecuteNonQuery()
at SoftGrid.Management.DataAccess.ApplicationsBase.Add(ApplicationsData data)
at SoftGrid.Management.Applications.Add(ManagedApp app)
— End of inner exception stack trace —
Server stack trace:
at SoftGrid.Management.Applications.AddApp(ManagedApp app)
at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Int32 methodPtr, Boolean Execute Context, Object[]& outArgs)
at System.Runtime.Remoting.Messaging.StackBuilderSink.PrivateProcessMessage(RuntimeMethodHandle md, Object[] args, Object server, Int32 methodPtr, Boolean Execute Context, Object[]& outArgs)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean Execute Context)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at SoftGrid.Management.IApplicationGroups.AddApp(ManagedApp app)
at ManagementConsole.ManagementSession.AddManagedApp(ManagedApp app)
I need your help.
Please help me.
Thanks a lot.
