Hi there,
An error occurred while initializing Microsoft Dynamics GP. Last time this worked just fine and now this. I have made the proper settings and can anyone help me please to fix this error ? What is causing this one ?
Thank you !
An error occurred while loading or initializing an addin. Ask your administrator to check the Windows event log for more details.
Dynamics will now close.
OK
Microsoft Dynamic GP error installing an add-in
Try to export resources from the current dictionary.
Go to the Microsoft Dynamic GP > Tools > Customize > Customization Maintenance.
Select the forms that you want to export from the dictionary > Select multiple forms by use shift or CTRL
In the ‘Please select a package file > select location where to want to save > click save
click Tools, click Customize, > Customization Maintenance.
Import > Import Package File > locate the package file that you created during the export process > Open.
Import Package File> OK .
Method 2:
Make sure all users exit Microsoft Dynamics GP.
1. Rename the Reports.dic file to Reports.bac.
Go to the Microsoft Dynamics GP.
Microsoft Dynamics GP > Tools > customize.
Click Reports > Modified Reports list should be empty.
In report writer click Import.
2. Click the ellipsis button > Open.
3. select the changed reports that you want to import > Insert > Reports to Import list.
4. Click Import.
