Microsoft Dynamics AX 2012 Setup
I copied the “Setup support” from another AX 2012 installation to this machine at following location: C:Program FilesMicrosoft Dynamics AX60.
Now I am able to proceed with installation but getting another error. This error is strange as AX set up is able to install the components and at the end it’s throwing this error. PFB the screen shot of error.
What did I do wrong?
Microsoft Dynamics AX 2012 Setup.
An unexpected exception occurred during Setup.
See the log file C:Program FilesMicrosoft Dynamics AX60Setup Logs2012-02-08 17-17-37DynamicsSetupLog.txt for details.
Answered By 10 points N/A #149674
Try the following solutions:
1. Click on the "Open the log file when setup closes" option and download the log file. Check the log file to see what is causing the error.
2. This error could occur when the source of the setup file is suddenly removed from the system. If you have the setup file on a USB drive or a CD then make sure that you do not remove the disc till the setup completes.
3. Check the compatibility of the software and see whether it is compatible on your system. If it is not compatible then download the version which is compatible with your system.
4. Disable your antivirus and then try to reinstall the software on your computer.
