Hi experts,
Even I have install SQL Server 2005 on my PC I still have this error. I don’t understand why because I meet all the requirements to run this program.
Anyone knows why? What might be the problem and how can I solve it please?
Thank you!
Microsoft Dynamics AX Setup
You must install SQL Server 2005 Analysis Services with Service Pack 2 or higher before installing the Analysis extensions.
OK
points
Microsoft Dynamics AX Setup error. Sql issue
SQL Analysis Services for DAX 2009 is one of the greatest annoying components to install. This error message means there is an Analysis Services 2005 version of the Microsoft.AnalysisServices.dll file in the Global Assembly Cache. Microsoft Dynamics AX doesn’t support running Analysis Services 2005 & Analysis Services 2008 on the similar PC.
To solve this problem, uninstall the Microsoft.AnalysisServices.dll file that has a version number of 9.0 from the Global Assembly Cache usually located at “C:Windowsassembly”. Go to this folder and eliminate all references to the of the Microsoft.AnalysisServices.dll version 9.0. For more info on removing and adding reference you can see this page gacutil.
On running the installation again, you can see the following image:
After completing the installation steps and you will get the following screen.
