Microsoft Dynamics CRM Recurring Problem Component not Installed?
Need help with Microsoft Dynamics CRM, this happens when I tried to launch the report using report server, when I look at it, the message box appeared. I run Uninstaller and reinstall everything, but the problem still occurs. Anyone can help with this problem?
Microsoft Dynamic CRM – Webpage Dialog
Reports cannot be run because the connector for Microsoft SQL server reporting services, a required component for reporting, is not installed on the server that is running Microsoft SQL Server Reporting Services
Regards
Marty
