Microsoft Dynamics GP 10.0 File not found VB6.DLL
Hi everyone,
On my system I have installed Windows 7 with MS Office 2010 and I have installed Microsoft Dynamics GP 10.0. I don’t know what the main problem is, but when I have finished first modification in Microsoft Visual Basic. Online I have searched for solution, but I didn’t want to apply any. Here I wanted to get answer for my problem. Is anyone have solution for this issue?
Thanks
Justin
File not found: VBA6.DLL
Microsoft visual Basic
Answered By 10 points N/A #123279
To resolve that problem, you will need to try the following fixes:
  • First you will need to try downloading and registering a new copy of the VBA6.DLL and see  if that will resolve the problem.
  • In case the above resolution fails to work, then you will need to try a registry edit since the problem may be with the registry entries. You will also need to try a deletion of several files from the Dynamics GP folder and see if that will resolve the problem.
In case you need more information on how to edit the registries and delete files, you will just need to visit the following site:post by Beth Gardner which is describing the same problem.
-Thompson Locker
