Ollivia
Posted on - 12/19/2011
Hi everyone,
On my system I have installed Microsoft Dynamics GP 10 on Windows Vista. The problem that appeared recently is error message. I got it when I click on OK after finishing calculation on payroll check.Did anyone had this problem? Can it be fixed?
Thank you
Olivia
The FICA/Social Security tax table cannot be found. Paycheques cannot be calculated.
Microsoft Dynamics GP The FICA/Social Security tax table cannot be found
To resolve that error, you will need to follow the steps below:
You will need to open the application.
And when you have done that you will need to go to Tools.
And then you will look for Maintenance and click on it.
Next look for the US payroll Updates and click on it.
And then you will click on Check for Tax updates.
What the procedure above is meant to do is look for the latest updates and install them. That will help fix any bugs that might have been there in the old version that was not yet updated.
-Thompson Locker
