Microsoft Essential Error Code: 0x80004002
My anti-virus (Microsoft Security Essentials) says I should update, but when I try it gives me this Error Code: 0x80004002. Previously my pc was affected by some malware which prevented the update of malware bytes..
But now it's working good.
Virus & spyware definitions update failed
Microsoft Security Essentials wasn’t able to check for virus & spyware definition updates. Make sure your computer is connected to the Internet and try again.
Click ‘Help’ for more information about this problem. Error code: 0x80004002
Error description: Microsoft Security Essentials couldn’t download the definition updates because your computer is using an older version of the Windows Update client or because Windows couldn’t start the service that transfers data.
OK Help
Please help
