Microsoft Excel Error: Range Specified
Greetings, everyone!
I'm not very familiar with MS Excel, as I use MS Word more. This week however I have a project I have to complete in spreadsheet. I got this error and the Help assistant keeps giving me the wrong answers and entries. Can anyone help me with this problem? Thank you all so very much.
Microsoft Excel
The command could not be completed by using the range specified. Select a single cell within the range and try the command again.
OK
Answered By 0 points N/A #94020
Hi there! I'll be happy to help you with this problem because I always use MS Excel. I used it almost everyday actually. You cannot really complete the command if you are trying to export a list of file in the MS Excel. But you can use table to be able to create or change a list in your report/project.
Make sure that the command you are using is appropriate to all the data that you are entering in MS Excel for it is very sensitive and will cause error. I recommend you to review the data that you entered in spreadsheet. Again, don't export list of files in excel or else you'll receive the same error. I'll be glad to hear if this will work for you.
Garry
