Microsoft Exchange Error failed to mount database
Hi there,
This morning I had some errors with Outlook and I discovered that it was disconnected. Also I have checked Exchange Server and the Database it was not mounted. While I was trying to mount again the Database this error appeared and I am stuck with. Any solution for this error ? How can I solve this ?
Thank you !
Failed to mount database ‘Mailbox Database’.
Mailbox Database 0612536984
Failed
Error:
Couldn’t mount the database that you specified. Specified database: Mailbox Database; Error code:
An Active Manager operation failed. Error: The database action failed. Error: Operation failed with message: MapiExceptionCallFailed: Unable to mount database. (hr=0x80004005, ec=-515). [Database: Mailbox Database, Server: server.domain.local]
Answered By points N/A #189621
Sounds like database corruption or misconfiguration. In order to fix this issue, you have to repair your database.
To do so,
1. Start an elevated Command Prompt.
2. Run the following command:
eseutil /mh "C:Program FilesMicrosoftExchange ServerV14MailboxMailbox DatabaseMailbox Database.edb"
3. If you see “Dirty Shutdown” as below,
Do the followings.
4. Run the following command to repair the database:
eseutil /p "C:Program FilesMicrosoftExchange ServerV14MailboxMailbox DatabaseMailbox Database.edb"
If you see “Clean Shutdown” in “State” field, you have to inquire the Exchange logs for further details. To do so,
1. From the Command Prompt, run the following command:
eseutil /ml "C:Program FilesMicrosoftExchange ServerV14MailboxMailbox DatabaseE00"
Now, your issue should have been solved.
Note: if you see “Clean Shutdown”, you can safely remove the logs.
