Microsoft Exchange Server 2010 SP2 Download?
Hi All,
Where can i download the SP2 for Exchange 2010Â
What are the new changes/fixes done in this SP2?
thank you
Hi All,
thank you
Hi Ileum,
You can go here https://www.microsoft.com/en-IE/download/details.aspx?id=36768Â and download Microsoft Exchange Server 2010 service pack 2. This new update provides greater reliability as it is more flexible, user interface and experience is enhanced and a much better and improved protection. It is more reliable and flexible as it tailor the deployment style based on your business needs. Users are now able to access in a secured setting their communications on any platform. It also delivers a highly sophisticated loss prevention tool targeted to simplify the process of protecting the company.
Before deployment, make sure your computer meets the minimum system requirement for the application to run.
Aristono
Since you are asking about Microsoft Exchange Server, why not try or upgrade to version 2013. Microsoft Exchange Server 2013 features DLP or Data Loss Prevention. This avoids any users from incorrectly sending sensitive information to unauthorized users or people. It will also notify them of internal compliance guidelines. The mobile device policies available in the program will allow you to create a list of accepted mobile devices.
You can also impose PIN lock and or eliminate restricted company data from lost mobile handsets. It permits you to sustain control, keep your organization secure, and improve user productivity. With Microsoft Exchange Server 2013, it lets you customize your solution based on your exceptional requirements. It also guarantees that your communications are always available while you are in control.
You need to register first to download Microsoft Exchange Server 2013.
