Microsoft File Server Migration Toolkitusing Simple Steps
Asked By 15 points N/A Posted on -
Hi. I am not very thorough with the concept of migration toolkit. I would like to know the system requirements and the steps to install the Microsoft file server migration toolkit. Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #155697
Hi. The requirements for Microsoft file server migration toolkitare a Windows Firewall to allow the calls for WMI as the file server migration wizard. Windows NT Server 4.0 must be compatible on the source file server. The Windows Server 2003 family must be run on the operating systems. The NTFS file must format the target volumes, and the source folders should be shared. To install the migration toolkit, the steps to be followed should include downloading the application as the first step. Next, open the file menu and then click on save.
To save the file, choose a location and then select the save option. In the end, open the location wherein the file has been saved in Windows Explorer, click on it twice so that the installation process can be started and then follow the instructions which appear to complete the installation. Hope we helped.
