Hello Guys,
I am using Microsoft Fortran Power station 4 Professional on Windows XP machine. I am planning to have Intel Core 2 Duo with Windows 7 64 bit, will I be able to use Microsoft Fortran Power station Windows 7 ?
Please do the needful for providing the inputs,
Raymond D Caswell
There is nothing to worry about if you upgrade your OS, and also your processor. But after installing the the Microsoft Fortran Powerstation it won't probably run on a 64 bit Windows 7 because the software is a 32 bit version. To avoid this problem simply run it in compatibility mode and choose your compatibility OS as XP service pack 2.
