Hi there,
During the install of Microsoft Lync Server 2013 this error message box appeared and I had to click OK hoping that the install will continue, but it didn’t. Any solution ? Please an expert help me please to install this properly.
Thank you !
Microsoft Lync Server 2013, Debugging Tools installation or uninstaller requires that Microsoft Visual C++ 2012 x64 Minimum Runtime – 11.0.50727 Package is already installed. Either use Setup.exe for installation or run vcredist_x64 included with the product to install the redistributable.
OK
points
Microsoft Lync Server 2013 Debugging Tools Setup
Microsoft Visual C++ is one of the greatest products supported by Microsoft. The error is requiring that Microsoft Visual C++ 2012 x64 will be installed.
The program you’re trying to install is built using Microsoft Visual C++ 2012 compiler that makes the EXEs dependent on the specific runtime. The redistributable package is available on 32-bit and 64-bit environment.
Download Visual C++ Redistributable for Visual Studio 2012 Update 4. According to your OS, you should download both x86 and x64 package. After completing the installation, run the Lync Server 2013 installer.
Most definitely, no more problems for sure.
