Microsoft Money Plus Sunset installation error
I use Microsoft Money Plus Sunset at my office PC.
Now I need to install it in my home PC but when I try to install this in my home PC the following error occurs.
Please let me know, how can I fix this?
A required resource cannot be located.
Best Answer by Carney goff
Answered By 0 points N/A #132325
Hi Rudy,
I think the information what I am giving you now can be helpful for you. Try what I say now. Create a new Windows user with Administrator privilege, switch to the user and install Money Plus Sunset.
I think your problem should be gone. Thanks for asking.
Hathy Greave
Answered By 0 points N/A #132326
Hi? The Money plus Deluxe sunset can be used to replace Essentials, Deluxe and Premium Money plus.  This error you are experiencing because there is another version of that same program that you are trying to install, already installed on your computer. Do uninstall the already installed version then buy a product key from this link. http://www.microsoft.com/en-us/download/default.aspx. I hope this solves your problem.
