Hello friends
I have recently formatted my window 7 64 bit but after formatting it successfully I am experiencing some problems.
The windows is now creating some issues when I try to install some applications.
The applications I tried to install are Corel Draw x 5, Nero 8, Nero 10 3DS max 2012 and also the Batman Arkham Asylum.
When I try to install this game, I get a direct error. It is some kind of a Microsoft .net framework error. The screenshot of that error is attached below:
Microsoft .NET Framework
Unhandled exception has occurred in your application. If you click
Continue,the application will ignore this error and attempt to continue. If
you click Quit,the application will close immediately.
Could not load file or assembly 'Microsoft.DirectX.Direct3D.
Version=1.02902.0. Culture=neutal.
Publickey Token=31bf3856ad36e35' or one of its dependencies. The
system cannot find the file specified.
Details                     Continue      Quit
I searched a lot for this on different forums but the only solution I could think of was to reinstall windows .net framework but unfortunately it didn’t help me out.
While I was trying to install Corel Draw X5 I got the following screen:
CorelDRAW Graphics Suite X5
Error 2908.Could not register component
(81AC5999-7A58-BA84-073F8EA9CA5F)
           Abort  Retry  Ignore
If I ignore this message, I get another error on my screen. The screenshot is as follows:
Error 1935.An error occurred during the installation of assembly component
(81AC5999-7A47-4A58-BA84-073F8EA9CA5F.
                                     OK
I tried to fix it by trying different registry repair software and also tried to tune up utility 2012 but all in vain. I really frustrated now as I have not found any solution yet.
Please help me to fix the issue. I'll be really thankful to you all.
Kind regards
David
Microsoft .net framework program error
Dear Stephen
According to the DirectX error message you received, please try to follow these steps in order to get rid of this error message:
Try to run System File Checker scans https://support.microsoft.com/en-us/help/929833/use-the-system-file-checker-tool-to-repair-missing-or-corrupted-system
It allows an administrator to scan all the protected files and verify their version. If a protected file has been overwritten, it replaces the file with the correct version from the cache folder or from the windows installation source files. Then, System file checker repopulates the cache folder. You must log onto your PC as an administrator in order to run System File Checker. In case the cache folder became unstable or damaged, try to use sfc /scannow to repair its contents, sfc /scanonce or sfc /scanboot.
Regards
I think this problem that you have encountered is just because of the problem with the out dated version of Microsoft .Net Framework as you have mentioned its version as 2.0 like something.
Install the newer version and you may get rid of this problem.
I would like to say that Microsoft developed the latest version of Microsoft .NET Framework 4 4.0. 30319. 1.
You can download this from internet free of cost as it is a freeware. For your downloading support, I am giving you a downloading link:
http://www.microsoft.com/net/downloads
Here, the installation of or the update of 3D card and directx is also recommended
I think your problem is solved by now
Thanks for having your time
