Microsoft Office 2007 customize installation
I have Office ’07 Pro Plus but I only want to install Word, Excel, Outlook and PowerPoint. How do I exclude the others?
Hi Debra,
During the installation you have many options where you can choose to install your Microsoft Office individually. Typically, when you first install office 2007 it install automatically if you just click always "yes" on the process I'm sure you install the whole feature of the office including Word, Excel and Outlook etc.
If you have existing office program in your PC. try to remove unnecessary features by following this steps:
1. Click Start.
2. Control Panel.
3. Add and Remove Programs.
4. Select the program you want to remove features and click continue.
Thanks,
Ken
If you installed the full Microsoft Office 2007 suite, removing or uninstalling the applications you don’t want to use would be easy. You simply need to modify the installation from the Control Panel. To remove the applications you don’t want to use, click “Start”, “Control Panel” then “Add or Remove Programs”. In the Add or Remove Programs screen, scroll down and select Microsoft Office 2007 then click “Change”.
On the next screen, make sure “Add or Remove Features” is selected then click “Continue”. In the Installation Options screen, set all applications that you don’t want to use to “Not Available”. You should now see a red “X” before the application’s name indicating that the application is not available or will be removed if it is still installed.
When you are finished setting the applications, click “Continue” then follow the instructions. And that’s it.
Notifications
