Microsoft office 2007 problem – technical
I need to know how to draw graphs in excel for my job purpose and I do not know the method. I like to have some suggestions on how to create graphs on excel using some raw data. Should someone know how to do it kindly instruct me with the necessaries.
Ariel Chu
Answered By 0 points N/A #109713
Here’s how to make graphs in Microsoft Excel:
  1. Enter all data into the spreadsheet.
  2. Select the entire data range, plus the headings.
  3. Select the “Insert” tab.
  4. Choose what kind of graph you’re creating from “Charts”. Also choose the chart sub-type.
  5. You can customize and change the size of your graph by dragging its corners.
  6. Put the graph on where you want it to be by dragging it from its white background.
That’s just the basic. If you want to customize your graphs more like changing the colors and backgrounds, here’s an online video tutorial site that can be very helpful.
