Hello Friends,
The problem is with my Microsoft Office 2007. Yesterday all on a sudden it threw an error message as it has stopped working. I reinstalled Office but the same error message did not recovered. Have you any idea for the error message?
Please help me to get a remedy of this issue. My machine is running with Windows XP.
Thank you.
Microsoft Office 2007 Stopped Working, reinstalling did not work
You didn’t mention exact error. But I will tell you how to repair the Office 2007.
Please follow the instruction that I have given below.
Click Start then go to All Programs.
Locate the Microsoft Office and click Microsoft Office Tools.
Then click Microsoft Office Diagnostics. You can see a new window appears. Click Continue.
Hope this will solve your problem.
I can help you fix the issue with Microsoft Office 2007 on your computer. I suggest you to perform the following steps:
>>Create a Restore point on your computer before performing any troubleshooting steps.
>> Start Word 2007, click File, and then click Options.
>>Now, click on Add Ins and click “Go”.
>>Uncheck the “Send to Bluetooth” and then click “Ok”.
This should fix the issue with Microsoft Office on your computer. Just in case if this does not help, try disabling other add Ins that you see under “Options”. You can also contact Microsoft Support to fix the issue.
Thanks and regards,
Skarbos Jay.
You didn't mentioned the exact error which you were getting.
However, I would still recommend you to repair your installation.
Go to Control Panel –> Add or remove programs. Select Microsoft Office 2007. Then select "Repair" and follow the on screen instructions to repair your installation. Once done, your problem should have been solved.
If your problem persists, I suggest you should contact Microsoft support regarding this. You can contact them using the link given below.
Link: https://support.microsoft.com/en-us
Hope this helped!
Drianna allen
