Microsoft Office 2010 encountered an error during setup
Hi Guys,
I am facing a tough time during the installation of MS Office 2010 Professional Plus on my system
Hi Guys,
Hello Himan,
You may be having those problems when installing Microsoft Office Plus 2010 for several reasons:
Carl
Dear User,
This error mostly appears when there is a previously installed office based application isn’t removed completely.
In order to fix this. Please try the following steps,
1. Make sure you uninstall previous versions of office suite completely from your computer, if the windows cannot remove it completely. Use a third party tool to remove it.
2. After removing it you should if possible download another setup file to install office suite
3. Because the existing setup file may have some corrupted files.
4. But however this should fix your problem.
Thank youÂ
