Microsoft Office 2010 Installer cannot be accessed
I need some help installing Microsoft Office 2010. My operating system is Windows 7 and whenever I run the installer I get an error report saying: “error 1719 installer cannot be accessed”. Will someone walk me through this? Any help will be appreciated. Thanks!
Answered By 0 points N/A #130351
The problem is with the minimum system requirements.
Try these.
Download Microsoft .NET framework from the internet and then install it to your machine.
Delete any other previous installations of the Microsoft Office. I mean delete if uninstall not possible.
Open the registry in the regedit.exe and then delete the Office entries.
Download the latest updates of Windows 7 and then install the Office.
See whether any firewall or the antivirus blocking program has blocked the installation. Sometimes when some files get corrupted or affected by viruses, the antivirus programs detect them and then deny theirs access for execution. As such you need to disable them but that may harm your computer. Obtain a fresh copy.
